Old 11-26-2007, 04:48 AM
iieeann iieeann is offline
Senior Members
Question Unable to extract archive with chinese/japanese characters.
Whenever I come across filename with chinese or japanese characters, PA2007 will not work (right click). I have to rename the file to make it work. Is there a workaround for this? Don't tell me that i have to install chinese (sim), chinese (tra) and japanese 3 versions....
Why can't PA2007 support unicode?
Thank you.
Old 11-26-2007, 08:00 AM
TBGBe's Avatar
TBGBe TBGBe is offline
Still Mainly Lurking
Probably best if you check info and follow up on the other thread.
extraction error for chinese filename
Terry
WinXP SP3
