Closed Thread
Old 09-19-2007, 02:54 PM
cnewton081702 cnewton081702 is offline
Junior User
Question Powerarchiver 10.x and Terminal Server
Application installed to a two node NLB Terminal Server. Both servers have had the product registered locally. When the client connects to the TS to use the application it tells them they are running an unregistered version. Run the application from the server no such prompts as registration is complete. Does each client connecting have to register or is there something I missed during the installation of the application.
Old 09-19-2007, 03:00 PM
you need to use advanced installation instructions which will tell you how to pre-register PA for all users on that computer.
You can get it by emailing support via form above. Closing the thread.
Closed Thread
