Using latest version (rc2) unable to........
Sorry to report this, I'm sure you guys are getting close to releasing a new version but I found a problem. If I right click some archives and try to extract them, the extract option is not available. I am only able to compress them. However, if I open the archive first, I am able to extract the files without any problems. I am using the 64 bit version of Vista.
The links below are just a few examples of archives I am unable to extract using the right click option. Creative sound drivers Nvidia video drivers Latest Powerdirector patch Thanks. |
did they work before? Support for them probably has to be added specifically... thanks.
it works fine here - did you check Options> Conifg> Misc.> CAB SFX option under Speed menu?
that might be it... thanks
I have been unable to extract the Nvidia archive for a while with the Vista 64, and I assumed Nvidia changed their archives for Vista until I was able to extract the files (via right click) with XP PRO. I have not tried the latest version (10.20.17) with vista 64, but I am assuming the issue was not addressed. I will try the lastest version when I get home from work today. Thanks.
That's great news! I'll try it when I get home today. Thanks again.
