Colums after first start
When you first start PA. the filelist has the columns according to image. As you can see, some columns are hidden, but do have a column width > 0.
Windows 7 x64 (NLD/ENG), I5-760 |
I must admit, it would be nice to have the ability to hide/show these column headings like you can in Windows Explorer!
PA Can this be done?
The issue should be fixed in Beta 3.
=-=-=-=-=-=-=-=-=-=-=-=-=-=-= PowerArchiver Support http://www.powerarchiver.com =-=-=-=-=-=-=-=-=-=-=-=-=-=-= |
Please check with Beta 3 preview:
http://www.powerarchiver.com/test/re...warc1020b3.exe and let us know if it works properly now. thanks!
Not fixed in b3.
You must delete PA registry key to make it similar as first start - then try again.
That did the trick. Fixed in b3
not fixed in b3.04.
fixed in .15
