Old 01-23-2007, 11:46 AM
Virtual_ManPL
Guest
Posts: n/a
Exclamation Extract to filename\ - bug- PA2007 B6 (FIXED)
When I have 2 archives like:
and choose 2 archives and select options Extract to filename\
the both archives unpack only to one folder like:
but it should be like that:
I use PowerArchiver 2007 10.00.22 Beta 6
Old 01-23-2007, 12:21 PM
dougw dougw is offline
Junior User
I also have an extraction problem. When I right click a zip file I used to see Extract To: but that option is no longer there. I have gone into the configuation and under Shell Extension - Extraction and have the extraction types on the right side but it does not appear in the windows explorer.
I am using the 2007 B6 version. I have tested this under Windows XP SP2 and Vista Ultimate RTM.
Any ideas?
Thanks,
Doug
Old 01-26-2007, 09:03 AM
Virtual_ManPL
Guest
Posts: n/a
Exclamation
Not fixed in PowerArchiver 2007 10.00.24 Beta 7
Old 01-28-2007, 12:55 PM
ivan's Avatar
ivan ivan is offline
Alpha tester
The issue should be fixed in Beta 8.
PowerArchiver Support
http://www.powerarchiver.com
Old 01-30-2007, 01:57 PM
Virtual_ManPL
Guest
Posts: n/a
Thumbs up
Fixed in PowerArchiver 2007 10.00.26 Beta 8
