Encryption not recognized in Windows XP
I have created several encrypted archives on my machine at home. I tried taking one of them to work on my USB drive.
At work, I tried to open the archive. It opened fine. But when I try to access the files, and enter the password, nothing happens. It's as if I am typing in a wrong password. This even happens if I use Power Archiver 2000! But if I use the shareware Power Archiver 2006 at work, all is well and it recognized the password. Why do Windows, Winzip, and Power Archiver 2000 all not recognize the password I used in Power Archiver? |
simple answer
use latest powerachiver
2006 and if still having a problem can u send us the file and with password and we will try to see if it work usually it can mean either a had disk faliure at encryption or your password is wrong. JHave any of the file go separte passowords. i have had this problem. can you tell us your system windows xp 200 etc and what version of pa u are using and what file types are in the file and passowrd and as much detail as you can please |
Also, you say you encrypted it - not just passwrod protect. I think Windows only supports the (old) Zip password scheme and not encrypted files (but I am not certain). PA 2000 (version 6 ??) also only supported Zip password and did not support encryption. So I can guess it may be the same problem with WinZip. Which encryption method did you use? Quote:
Terry WinXP SP3 |
WinZip will work fine as long as it is newer version of WZ, same with every other zip utility that supports PkZip 4.5 standards.
I am pretty sure that newer versions of Windows support it as well. thanks,
simple method did you encrypt with aes zip or pae encryption from the too bar menu in poawerarchiver as that format is not supported by windows.
