Compress by Command Prompt
Hey.
Is it possible, to write a command promt in Power Archiver ? (like arj a - etc.) I need a cmd file to plan a daily zip action in the Task Scheduler. Thx Bernhard |
Not for compressing, but your PowerArchiver License also gives you a License for PACL which is the "command line" version.
Note: PACL does not (yet) support ZIP > 2GB.
Terry WinXP SP3 |
Thanks.
I used this: pacomp -a -r -c2 d:\usertemp\usertemp.zip w:\alle\user_tmp\*.* The Folder W:\alle\user_tmp includes many folder. The program compress all files, but he copy all files into d:\usertemp\usertemp.zip Without the many folders ? Please Help. THX Bernhard |
Is the problem that paths are not saved or that you dont see them, or that subfolders are not added?
IE. Does changing View> Explorer display style show you the folders? thanks,
