How do you Test All Files in Subdirectories???
I have a few hundred archives in one folder, but they are spread out in in a few hundred subdirectories (and they have different passwords).
My question is how do I can I test all the archives at once, how can I test and have it recurse through all the directories??? Winrar lets you test and recurse through subdirectories, but it doesn't have a password manager, so it takes me like an hour to test all the archives, because it stops and I have to enter each password every time. I thought PowerArchiver solved the problem with the Password Manager, but it doesn't recurse through the subdirectories, from what I can figure out, you have to manually select each archive one at a time to test. That would take me several hours to test. |
You can test multiple archives from Windows Expolorer. Select multiple archives and choose 'Test' from the right-click menu. If the option is not there, turn it on in PowerArchiver -> Options -> Configuration -> Shell Extensions. But this only works for multiple files. No subfolders are scanned hence no files from subfolders will be tested.
=-=-=-=-=-=-=-=-=-=-=-=-=-=-= PowerArchiver Support http://www.powerarchiver.com =-=-=-=-=-=-=-=-=-=-=-=-=-=-= |
In windows XP: go to the directory with all the files and subdirectories, then press F3 to do a search, then enter *.zip,*.rar, *.exe from there I can highlight all the files and right click and test them all. I hope in the next version of PowerArchiver you put the ability to to recurse through subdirectories. Last edited by eraserhead; 01-05-2006 at 04:27 PM. |
